GM Flexfuel sensor
Hello
I have installed a GM flex fuel sensor (Part nr 12570260) on a rally car, but I have problems getting the M400 too read it.
The sensor is wired looking into the sensor, from left to right, 1: Ground, 2: +12 V, 3: Signal. The signal is connected to 5 v with a 1000-ohm resistor.
The signal is wired too dig in 3 and dig in 4. Dig in 3 is set up with speed, Hz and dig in 4 is set up with msecs measuring.
The input signal is 0 and the raw input values are 0.
Does any one have an idea what can be wrong?
