Ref / sync sensor wiring query.
Apologies for the basic questions, new to wiring up a standalone ecu myself, so need to verify as i proceed.
I have removed the stock combination optical cam and crank position sensor on a Skyline RB26 engine and added a Marelli magnetic crank pickup sensor reading a 62 minus 1 tooth crank wheel, and a Bosch Hall effect cam sensor, reading a single camshaft wheel tooth. I want to use the stock Nissan engine loom as much as possible. I enclose a screenshot of the stock wiring up to the opti sensor connector. What I would like confirming is whether I can run the stock loom wires up to the plug, chop the plug off then split the ground and voltage leads to feed the two new sensors, and use the stock other 2 wires for the signal feeds to the ecu. It appears the 4 wires are encased in a common screen. Is this going to be OK done like that?
Bosch sensor data is at : http://www.mmcompsys.com/download_zone/ ... all_01.pdf
Stock wiring to stock opti sensor plug is in the image below, thanks.
