M880 settings for clutchless shifting
Thu Apr 28, 2016 3:27 am
by Richie webb
I am trying to get my car to shift clutchless, just fitted a full sequential gearbox and am using an Amplified shift knob strain gauge to tell it when to cut, I have read the motec technical note CTN0004 and as far as I can tell have everything set correct but when I shift it doesn't activate ignition cut.
I have the strain gauge wired into AV3 and when I look in View sensors I can see the numbers rise or fall when I move the shifter
Can anyone make suggestions to what I might have done wrong?
thanks Richie
Re: M880 settings for clutchless shifting
Thu Apr 28, 2016 6:25 am
by Arve Flaat
Hi
Try:
Cut mode: 2. form cut signal
Cut source: 4. Force channel
Gear cut force low or hige sett too right level (kg)
Cut level: 100%
AF
Thu Apr 28, 2016 6:45 pm
by Sean
Check also that you have gear detection set up correctly. As far as I recall, needs gear detection set up to work.
Or I could be wrong, got a lot on... Ecu config file will tell all
Sat Apr 30, 2016 5:25 am
by Arve Flaat
Hi
Quick shift works without gear detection.
If you whant the quick shift too work good you need gears to sett the shift times.
Long time 1-2 and short time 5-6.
AF
Wed May 11, 2016 7:00 am
by br21
Send me your map so I will have a look.
Thu May 12, 2016 5:44 am
by Richie webb
I have got it to work so thanks for the replies, now I just need to change my driving style to fit, to many years with H pattern and clutch so its not natural yet
thanks Richie
