Wideband Lambda Characteristic Table for LSU 4.9
I'm looking for the correct table for my oxygen sensor. If I use the values for the "LA1 Characteristic Table" as suggested in the help window, my lambda reads a little bit too lean, but over all seems to be just a little off. If I use the values from the data sheet (see link below) the sensor reads very lean. I did an air calibration after changing the table.
How do I set up my wideband lambda correctly?
http://www.bosch-motorsport.de/en/de/pr ... 626762.php
Kind regards
Kind regards
