Downshift into neutral
Hi All,
We are currently running an R6 engine with a Motec M800 ECU.
We have a modified gear selector barrel so that neutral is at the bottom followed by first, second etc.
Gear shifts are performed using a pneumatic actuator driven by auxiliary output functions.
Gear shifts are activated using two buttons wired into digital inputs.
Gear detection is performed using voltages from a gear position sensor.
The problem we are encountering is that the Motec will not shift down into neutral from first. I have not found any way to force this in the documentation. I have read something about a clutch signal being required, however, only in the Speed Lock Out option in Gear Shift Setup, which is currently off.
A simple solution is to just reconfigure the gear voltages so that neutral is read as first, first is read as second etc, however this outputs the incorrect gear to our dash.
Is there any way to force the Motec to downshift into neutral?
Regards
Mark
Regards
Mark
