Map Roc
Map Roc
Postby magovit on Tue Jan 19, 2016 11:48 am
Hi Guys,
In M800 i can't find MAP Roc. I use it to create a custom Accell based on map change.
Map ROC exist no Motec m800?
Thanks,
magovit
Re: Map Roc
Postby Scott@FP on Thu Jan 21, 2016 1:11 pm
You would use general setup/misc. setup/accel source = MAP. MAP RoC isn't displayed, but the resultant calc for 'fuel accel' is.
Re: Map Roc
Postby magovit on Sat Jan 23, 2016 11:40 am
You are absolutly right.
But my point of view is to use MAP ROC and TPS ROC together to create a hybrid Accell using Fuel Comp 1 and Fuel Comp 2.
I think Motec doesn't do it.
Hey Motec Guy's enable it please!
magovit
Re: Map Roc
Postby Stephen Dean on Wed Jan 27, 2016 4:55 pm
Hi Magovit,
Development on the Mx00 series ECU has been finalised, and no further work will be done on changes for them as we are concentrating on the M1 series of ECU's.
Could you do what you are wanting to do with a Aux Table and then take the output from that into the Fuel Comp?
I have been trying to understand what the aim of the hybrid accell comp is and what you are trying to work around, if you can provide some more information I may be able to point you in a different direction.
Users browsing this forum: Majestic-12 [Bot] and 16 guests
