Ref/sync not Synchronized.
I am using a Ross trigger kit with 12 tooth on crank and 1 tooth on cam in my RB25DET. First of all they wont synchronize, and because thats there I cant get no spark so timing light is pretty useless for finding the CRIP. Neither do i know the tooth ratio nor do i know the crip, this is as hard as cracking the safe and i tried literally close to 25 combinations before my battery runs flat and no luck. There is only one mark on the pulley no degrees to show anything else. Now how i can get the crip?
A. Clockwise distance of the mark on th engine to the mark on the pulley?
B. Clockwise distance of the mark on the pulley to the hall sensor?
In the webinar it says the first index tooth is the next after the sync tooth, but how do we know this? By a ref/sync capture as a measure? Coz mine doesn't show degrees but i can count.
Ross Balancers a.k.a Omega technical industries say each tooth is indexed at 30°s to one another. And i used the following setting in the Ref/sync setup.
1. Multi tooth.
2. Number of teeth 12
3.CRIP: no idea literally tried everything from -10 to 719, test advance was also fiddld with from 0-30 degrees no luck.
4. Polarity combination : as advised by motec one fall one rise, or both rise.
5. Filter table set as described by help file.
6. Sync tooth on exhaust cam, whose offset is 360÷1 as explained in their example if having 8 teeth this must be 360÷8=48.
Now where am i wrong? I kept smashing the enter button after changing combinations in the diagnostic screen never it says synchronization ok. Only once it happened at -10 crip , i hit the enter again while cranking to check for consistency and that miracle never happened again. Dont wanna send car 1500 km away to tuner, wanna do this myself. Somebody advice.
1. Multi tooth.
