M800 with high pressure injection?
Hi folks,
We are a formula student team and are currently running a M800 ECU with two injectors per cylinder at different distances on a Yamaha R6 engine. We use two injectors to improve mixture, since we are running with E85.
Now we want to improve mixture even further and consider the concept of a high pressure port fuel injection.
Which components do I need to run high pressure injection, apart of the high pressure injectors and pumps? Is the M800 capable of running high pressure injection? If not, I found the M1xx-Series which is capable of direct injection. Does this mean that the system is capable of high pressure injection? Is the software comparable to the M800 software and analysis software?
Thanks a lot.
Greetings
Thanks a lot.
Greetings
