How many IAT sensor EVO9 have?
Postby echo sh on Sun Dec 21, 2008 11:35 pm
Use a three pins Delco MAP sensor .clamp the tree wire on the stock MAF sensor 0V 5V single,but do not connect the connector to the sensor ,I want to know how ECU to capture the IAT single to compensate?whether or no have two,one on the air box ,the other on the air port?
echo sh
Re: How many IAT sensor EVO9 have?
Postby RossB on Mon Dec 22, 2008 1:26 pm
Most EVO9s have 2 air temp sensors, one fitted in the MAF sensor and the other bolts on to the top of the plenum chamber. There are some versions which do not have one on the plenum chamber.
Postby echo sh on Mon Dec 22, 2008 4:34 pm
Thank you very much!
echo sh
Users browsing this forum: No registered users and 27 guests
