M800, GEMS and 2D logger
I am trying to connect a 2D stick canbus logger to an existing wiring loom in an EVO X.
The EVO X is equipped with a M800 that is sending data to a GEMS dashboard.
I connected two more wires in parallel just before the canbus wires enter the GEMS connector.
Now from here the two extra wires run (twisted) to a 2D canbus logger.
The problem is that when I connect either the 2D logger or a MICROCHIP Canbus analyzer in "listen-only" mode strange data comes in (only two strange CAN-ID's like 0xC3). When I connect either of the two devices in "normal mode" the right can-ID's are being observed, but I don't want to run in "normal mode" as it effects the system (fan starts running etc).
As there is already a direct connection between the GEMS dash and M800 ECU I would think I could run the 2D logger in "listen-only" mode as all acknowledgements should already be given by the dash.
I have tried running with or without the 100 Ohm resistor at the end of the canbus but this did not make a difference.
Does anybody know what could be wrong?
