Setup Ground Speed With M400 On Honda Jazz
Postby Loqy on Wed Sep 09, 2015 12:12 am
How to set up Ground Speed in M400 on Honda Jazz GD3 ?
I want to activate the Launch Control & need Ground Speed for setup Launch Control.
Regards,
Loqy
Loqy Siregar
Loqy
Re: Setup Ground Speed With M400 On Honda Jazz
Postby Scott@FP on Wed Sep 09, 2015 9:27 am
If you are pretty confident the sensor is hooked up to the ECU properly-
You must enable traction control (any value other than zero for slip calc mode) in order for ground and drive speed calcs to happen.
