KTM 400 EXC Triggers
I am on the Formula team at Cal State Chico.
Currently I am working on converting our new 2000 KTM 400EXC to EFI using the M800 that I set up on our GSXR600 last year. It has a stock crank sensor that triggers twice per cycle. I made a new valve cover that houses the SYNC sensor that seems to be working properly from the captures I have gotten. See attached.
My question is are there any built in modes that accommodate the REF triggering twice per cycle? I read through the modes on the M800 and I didn't see anything that would work with this setup.
If that won't work I have heard of teams machining a trigger wheel to press on to the crank so that the crank sensor sees a normal pattern, 24-2 for example. That is not out of my capabilities, but I would like to try to find a mode that works with my current setup before going on the route.
Thanks in advance.
Sam
Thanks in advance.
Sam
