REF/SYNC Mode 52
Can I get some more info about Mode 52 (Subaru 3R 6 Cylinder)?
I'm currently running mode 39, with LH cam sensor to SYNC input on M600.
It's configured and engine runs fine. However, I believe this is incorrect for my engine, 2003 EZ30R.
If I advance the variable cams, it will through the SYNC out.
I believe I should use the Crank sensor for both REF and SYNC. Is this right? (similar to REF/SYNC mode 38)
The LH inlet cam sensor is on Dig1, the RH inlet cam is on Dig2.
Any help appreciated, I really want to get this variable inlet cam timing working.
