HELP,ref oem mode?
Wed Jul 01, 2015 10:52 pm
by remivrt
HI, I have just a sensor ref ( 60-2 teeth).
in main setup : number cylinder 36.
but in ref/sync setup what mode is for just 60-2 without sync.?
Re: HELP,ref oem mode?
Thu Jul 02, 2015 8:37 am
by Scott@FP
Hit F1 key (help) when in # of cylinders and ref/sync mode, should explain fairly well what the different modes are.
60-2 with 36 as number of cylinders is a two missing teeth twice a cycle ref mode, no sync sensor, uses the missing teeth for sync, and 36 indicates 6 cylinder firing injectors once per rev, not once per cycle, synced to the missing teeth on the ref sensor. Ignition must be waste spark or distributor.
Thu Jul 02, 2015 2:09 pm
by AdamW
remivrt wrote:but in ref/sync setup what mode is for just 60-2 without sync.?
Further to Scott's reply, Mode 8 is what you want.
