strange issue
Hi ,
I have a Motec m800 on a evo 7 with 6 speed gearbox . not a PnP board
I tune this car with a map and inlet temp.
i use the delco 300kpa map sensor .
What i get is when i drive in the first 5 gears i can go futher then 1.7 bar and even 2 bar boost .
But when i drive in the 6 gear i get errors in the ecu on the MAP and TP sensor when i go higher then 1.7 bar .Also the map sensor dont read higher then 1.7 bar so 270 kpa .
i have checkt the +5v to the map sensor and tps sensor and this is good .
i hope that someone can help me .
thanks ,
Wouter
thanks ,
Wouter
