Close looped Gear change control
Hi guys,
I am trying to run the down shift rpm limiter on the seq with load cell shift knob on the Gp. N evo 9 tranny.
I have set up all gear detection as voltage, tailshaft speed calculation, gear voltage, gear ratio, wheel speed from MDC.
throttle blip is set up and working.
However, when I put in any value in the down shift rpm limiter in gear detection setup page, it cuts the ignition to 100% whenever I go into 2nd gear or up and laptop shows dual rpm limiter active.
Has anyone experienced same or similar issue with that?
I am trying to limit the blip so it will match the rpm when doing down shift.
Thanks,
Anthony
Thanks,
Anthony
