Close looped Gear change control
Postby anthony_hk2001 on Sat May 23, 2015 2:39 am
Hi guys,
I am trying to run the down shift rpm limiter on the seq with load cell shift knob on the Gp. N evo 9 tranny.
I have set up all gear detection as voltage, tailshaft speed calculation, gear voltage, gear ratio, wheel speed from MDC.
throttle blip is set up and working.
However, when I put in any value in the down shift rpm limiter in gear detection setup page, it cuts the ignition to 100% whenever I go into 2nd gear or up and laptop shows dual rpm limiter active.
Has anyone experienced same or similar issue with that?
I am trying to limit the blip so it will match the rpm when doing down shift.
Thanks,
Anthony
anthony_hk2001
Re: Close looped Gear change control
Postby anthony_hk2001 on Mon May 25, 2015 11:14 am
Update on this:
I got it working and I guess the tailshaft speed cannot be from calculation.
Once I connect the speed sensor from the gear box it has no issue.
Now I need some advice or recommendation on clutchless downshift setup to ensure there will be minimal wear and tear of the dog gear.
Is it better if I set the blip to 75% and about 175ms, and let the downshift rpm limiter do it's work?
or should I just go with what I got from the open loop test data logging of blip with 25% throttle?
Thanks,
Anthony
anthony_hk2001
