M400 - Yamaha 1800 Cranking Issue
Hi
I have a Yamaha 1800 Jetski engine that I am having issues cranking. I have gotten a lot closer by adjusting the Fuel air temp and engine temp comps and also some cranking compensation. The issue I have is that the first time to get it started each day takes a bit of coaxing. However as soon as it is started, if I then stop it straight away so that the compensations zones stay the same, then press the button it starts straight away. I am reluctant to adjust the compensations anymore as it behaves fine after the very first turn over.
I am reasonably new to this and still learning, and wondering what other things I can look at to assist with the very first start up.
Thanks in advance.
Thanks in advance.
