M400 - Yamaha 1800 Cranking Issue
Postby thedriver75 on Wed Apr 08, 2015 11:44 am
Hi
I have a Yamaha 1800 Jetski engine that I am having issues cranking. I have gotten a lot closer by adjusting the Fuel air temp and engine temp comps and also some cranking compensation. The issue I have is that the first time to get it started each day takes a bit of coaxing. However as soon as it is started, if I then stop it straight away so that the compensations zones stay the same, then press the button it starts straight away. I am reluctant to adjust the compensations anymore as it behaves fine after the very first turn over.
I am reasonably new to this and still learning, and wondering what other things I can look at to assist with the very first start up.
Thanks in advance.
thedriver75
Re: M400 - Yamaha 1800 Cranking Issue
Postby thedriver75 on Fri Apr 10, 2015 12:04 am
Reading some of the other cranking issue problems and resolutions, I just did a Ref Capture as a pre-emptive possible answer.
thedriver75
Postby sarbetto on Fri Apr 17, 2015 9:53 pm
Hello , Try to approach the sensor ref .
It does not seem a good sign .
Or before you change the position of the ref tries to change the ref trigger voltage.
sarbetto
Postby stevieturbo on Sat Apr 18, 2015 3:33 am
thedriver75 wrote:Reading some of the other cranking issue problems and resolutions, I just did a Ref Capture as a pre-emptive possible answer.
A screen shot only shows a small picture.
But it does look like a good clean signal with good voltage levels.
As to whether they match your setup config...no idea.
Users browsing this forum: Bing [Bot] and 3 guests
