I haven't sync.what mode is?
Postby remivrt on Wed Mar 04, 2015 10:08 pm
HI.I put a plug n play m800 subaru gt on a vw vr6.I have only one tooth sensor 60-2 and not sync.I have fuel but not spark.what mode is?
remivrt
Re: I haven't sync.what mode is?
Postby stevieturbo on Wed Mar 04, 2015 11:05 pm
remivrt wrote:HI.I put a plug n play m800 subaru gt on a vw vr6.I have only one tooth sensor 60-2 and not sync.I have fuel but not spark.what mode is?
What is a Subaru GT ?
And as it's a pnp unit, seemingly the crank/cam setups in those ecu's are intended specifically for those applications.
So what pnp unit are you trying to use ?
Postby remivrt on Wed Mar 04, 2015 11:53 pm
It's a M800 subaru gt 2000 .217 HP. with mode 2 MULTI teeth I have fuel. and when I use test output, INJ 1,2,3,4,5,6 IT'S OK , but IGN 1,2,3 nothing, not spark just a little noise in the coil
remivrt
Postby stevieturbo on Fri Mar 06, 2015 2:31 am
So you're using a conventional Subaru 2.0 4cyl turbo engine ?
What year ?
And I'm sure it has been said before, that PNP units will only work with the crank/cam setup they were sold for.
So are you using the OEM crank/cam trigger for the Subaru engine...and if not, why not ?
Edit...just read you're trying to use a Subaru pnp unit on another engine.
Really not sure you can do this ? Can you do a ref/sync capture to see if it reads ok ?
Postby remivrt on Fri Mar 06, 2015 5:52 am
No .I use a motor 2798cc . 6 CYL VW VR6..
It's not possible without Sync? :cry:
because a many ecu set without sync.
I have Just Ref signal 60-2.crip:77.
Sorry I am new with motec.
Thank for your help stevieturbo
remivrt
Postby remivrt on Fri Mar 06, 2015 6:01 am
If I use mode 49 720 degré mode (full sequential).? It's good?
I would do capture this week end.sorry I'm overwhelmed because of a delocation
remivrt
Postby AdamW on Fri Mar 06, 2015 10:28 am
For 6 cyl engine with 60-2 wheel on crank and no sync/cam sensor you need ref/sync mode #8 and you need to set number of cylinders to "36". Ignition outputs need to be wired in wasted spark arrangement.
Motorsport Electronics Ltd.
AdamW
Postby remivrt on Sat Mar 07, 2015 6:01 pm
thank you very much adamW, It ' very cool. just for my curiousity ,why 36 for number cyl ?
remivrt
Postby AdamW on Sun Mar 08, 2015 3:03 pm
remivrt wrote:just for my curiousity ,why 36 for number cyl ?
I dont know where the "36" and "48" cylinder terminologies came from but they have been conventions in the Motec software for many years. No. of cylinders = "36" is used to designate a 6 cyl, 4 stroke engine that is synced every 360° (rather than the more common sync every 720°)
If you use Ref/sync mode #8 with a crank trigger and set the number of cylinders "6", then we are telling the ECU that 6 cylinders would fire every sync event (360°), so you can see that setting cylinders to "6" will not work in your case.
AdamW
Postby harky on Sun Mar 08, 2015 8:59 pm
Adam
does it follow that 24 would be the "setting "for a 4 cyclinder ?
I was working on this issue some time back and fitted a cam sensor , bit was sure there was a way around that !
oh -- that was with an M4 too ??
cheers
harky
harky
