M800 with PLM, can I see which Lamda sensor has open heater?
I started my Skyline today after a long lay up. It has M800 ecu with twin Lambdas. It also has a PLM. The PLM readout box was showing C4 after a warm up. I know this is open heater, but can I run the lap top and see from "live data" from the ecu which of the two Lambda sensors is faulty please, or do I need to check at the sensor plugs with a multimeter? Thanks.
Until I can get a new Lambda can I turn them off in the software and run open loop? I can post the map if required, but it's on an old hard drive right now, it would be quicker to download from the ecu than fiddle about.
