TC aim slip table
I have been studing some traction control settings. Now I wonder what method is used best on bike.
Aim slip table that uses:
- rpm versus gear with a compensation map with throttle and gear as an percentage
or
-throttle versus ground speed.
I have found both used by high level teams. What is the benefit from one over the other?
Also I have a lean angle channel that I can use.
Now I use the first method but using the lean angle instead of the throttle channel.
I think it would be better to use the first method with the first compensation table and use a second compensation table with a lean angle versus gear.
or
