DBW M800 LS7
DBW M800 LS7
Postby vchet on Sat Dec 13, 2014 8:33 pm
Good day to every body.
We have LS7 engine with M800 ECU and trying to make our electronic throttle working. Our throttle is OEM (General Motors), from this engine. We performed connection and made tests "on a table" and a little bit scared to install it in the car with further starting the engine.
Maybe some body done this work, please give a tip about calibration the DBW, especially Loe Idle )
Any help is desired. Thanks a lot
vchet
Re: DBW M800 LS7
Postby vchet on Mon Dec 15, 2014 2:39 am
Works for now. Idle a little bit "nervous" but in the whole ok.
vchet
Re: DBW M800 LS7
Postby Russ on Sat Dec 27, 2014 6:13 am
Whats the part no of your throttle? (bosch number if poss)
https://t.me/pump_upp
Russ
Re: DBW M800 LS7
Postby vchet on Tue Dec 30, 2014 10:27 pm
The trottle is GM. The only № i have found 221105109__0803A and Q-code under the number
vchet
Re: DBW M800 LS7
Postby pbido on Thu Apr 16, 2015 4:40 am
do you have a map i am trying to set up dbw and trying to see different calibration
pbido
Re: DBW M800 LS7
Postby Stephen Dean on Thu Apr 16, 2015 10:27 am
Hi vchet,
The settings for that throttle are as follows;
Proportional Gain 120
Integral Gain 80
Derivative Gain 120
Period 1
Dead Band 0.3
Feed Forward 10
Negative Integral Clamp -10
Frequency 8000
Motor Volts 14
