Some NEWB questions about m800 & viper
Let me apologize from the get go for my complete newb questions as i am just learning. I have a motec m800 on my Dodge Viper and am wanting to make sure things are ok with a few things.
The car seems to be running rich at IDLE and has a hard time starting sometimes. Going through the system with the software i show that when i key on the fuel pressure ends up at 0 (from the sensor screen). When i was going through the other settings i noticed that injector output 8 seems to get voltage with key on, but then goes to 0 with the engine running (vs the other 7 doing the opposite). I am also not sure what other two outputs are for the other two injectors.
Key on Engine Off
Engine IDLE
I also had an error engine 8: open listed under diagnostics at one point. I found an injector wire that had worked its way out so i reattached it. The error isnt coming up at idle anymore but i havent drivin the car yet to see if it comes back.
I may be completely reading and understanding the system incorrectly but i guess thats why i am here asking. Can anyone provide advice or suggestions?
Thank you
Key on Engine Off
Engine IDLE
Thank you
