Can I use an M400 on Ducati Panigale
Fri Nov 21, 2014 5:25 pm
by Gomerz
Hi, I am hoping someone can advise If I can use an m400 on the Ducati Panigale 899 and if the m400 will be able to control the drive by wire?
Thanks.
Re: Can I use an M400 on Ducati Panigale
Sat Nov 22, 2014 4:07 am
by cra5hdown
Yes you can, you would need to enable the drive by wire option also if you plan to buy one I would get a marine one b/c it would be exposed to the elements.
Sat Nov 22, 2014 8:15 am
by Gomerz
Thanks mate, I was aware that dbw would need to be enabled, I was more curious if the panigale uses CAN to control the dbw motors like the BMW s1000rr?
And if I would need a DBW4 or not as I believe the panigale has 2 separate tb motors bit I believe they are controlled together.
