Aristo 2JZ-GTE VVTi M800
Hope all are doing well and I thank you all for the shared knowledge in this forum. Before I go into my inquiry I just want to give a small introduction about myself. I live in the United Arab Emirates and I have been tuning cars as a hoppy for a sometime but quit a couple of years because of life demanding priorities (family and work) but couldn’t stop myself from car modification and upgrading, guess I am addicted to it that’s why I couldn’t keep my Nissan 300zx as OEM car and ending up having a Motec on it.
The Issue that I have is I have installed a Motec M800 on a 2JZ-GTE before and it worked fine and now I need to install a Motec M800 for a friend of mine (can't say no to him) on a Toyota Aristo that has the 2JZ-GTE VVTi engine. I understand that the crank wheel is different since the VVTi one has 36-2 wheel. My questions is regarding the Sync sensor and the vvti activation. Should I use one of the Motec OEM Ref/Sync sensor preset setups? there are two setups that I thought might work, there is on for the Lexus IS300 and there is another one for a Toyota engines that has similar Ref and Sync setup as the 2jz VVTI 36-2 Ref and the 3 cam teeth, Which one should I use?.
Also I have been wondering since the cam Sync sensor is on the VVTi cam wouldn't that change the cam position when the VVTi turn on and off thus changing the TDC from the ECU stand point? Or I don’t need to worry about that?
It would be a time saver if someone can share a file for this with us ..
Best Regards
Best Regards
