enable / disable functions on top of map function
There doesn't seem any way to do the following, and I am wondering if I am missing something obvious.
How can you enable / disable a function controlled by an aux output, in addition to its mapped output? For example, I have the EGR valve operation mapped on a 3D table for throttle position and rpm. But if I want the output to become active only above a certain engine temp (eg 80 degrees), there doesn't seem a way of doing it without (say) using another output and switching a relay that disables the EGR valve. Can this enable/disable be done in the software?
There are also other maps where I'd like to be able to do this but cannot use a relay because the map controls an internal function (eg a change in fuelling).
Any ideas?
Any ideas?
