M400 Crank Signal on BMW G450X
I have an M400 operating a BMW G450X engine (Formula SAE Car). I'm trying to set up the M400 to run the engine, however I'm concerned that the M400 may not be seeing the crank signal as I wish. The crank signal comes from the factory crank sensor which is a magnetic sensor detecting 18 evenly spaced teeth on the stator housing. There is one tooth that is physically slightly longer, but appears on the signal capture as can be seen in the attached image.
I have set up the M400 to mode 5 (one missing twice) and falling edge. Looking at the signal capture, I assumed that the motec would be able to see the falling edges, but would ignore the falling edge with the 'kink' that occurs every 18 pulses (this is the longer tooth).
https://www.dropbox.com/s/o3htktkl446mah0/CrankCam%20Capture.PNG?dl=0
Ignore the dark blue and the orange trace in this picture. The light blue square wave is my custom cam sensor signal (hall). It picks up the cam lobe as it passes its upmost point (i.e. 180degrees after full open valve).
It can be seen that the longer tooth occurs 7 teeth after the rising edge of the cam signal (working from the left of the image).
I cannot get the cam and crank signals to synchronise. Is it possible that the motec is seeing the falling edge (with the kink in it) as a falling edge and thus does not see a missing tooth? Should I instead configure the M400 to look for 18 teeth per crank revolution? Sorry if this entire post is somewhat confusing and convoluted.
ADDITIONAL INFO: The error I am getting from the ECU Manager Software is; -Error Sync Signal
I have no spark. I have tested using the ignition test and my wiring is fine, however when cranking there is no spark.
However it should be noted that the M400 can see the raw sync signal as I have performed a ref/sync capture and the trace is there (same as above figure).
Cheers,
Seb
Cheers,
Seb
