Detonation on fast gear change
Sun Sep 07, 2014 8:03 am
by JulianEdgar
I have a transient detonation problem on fast (eg 1-2) gear changes.
Can you pull back timing based on rate of accelerator pedal movement, or is there some other approach that will work?
M400 on Honda Insight turbo.
Thanks for any advice!
Re: Detonation on fast gear change
Mon Sep 08, 2014 1:22 am
by stevieturbo
There is an advance/retard feature much the same as fuel transients that should do what you need
Adjust, Ignition, Accel advance
open the window and hit F1 for info
Mon Sep 08, 2014 6:22 am
by JulianEdgar
It doesn't do negative numbers though - ie you cannot retard on acceleration, can you?
Mon Sep 08, 2014 7:48 am
by stevesingo
Menu
General Set Up
Ignition
Set Up
Ignition Accel Mode: You have the option of retard on Accel, Advance on decell or Advance on Accel and retard on decell.
Mon Sep 08, 2014 7:59 pm
by JulianEdgar
Thank you!
