Hello mates,
Would anyone have ref/sync mode and crip parameters for Toyota 2UZ engine or better yet a start up file?
Ref/sync capture attached
Thank you
Alex
Your “sync alignment” doesn’t look so bad to me, I would expect it to work ok.Alex B wrote:From what I see in ref/sync scope there is a problem with the ref and sync trigger edge alignment very close.
If you want to change to batch fire mode, then the following changes should do it;Alex B wrote:Both injectors and coils are wired for batch fire so what would be a proper cylinder and ref/sync mode for this setup?
My thinking its 24 for cylinders and mode 8 which doesn't require sync therefore solving ref/sync edge alignment issue.
Often by doing a ref/sync capture with only #1 spark plug fitted you will get a ref trace with a significant ‘dip’ or trough in just one area – the centre of this trough area indicates roughly TDC #1 cylinder on compression stroke. Unfortunately though this effect is not very distinguishable on your second capture – maybe this engine just doesnt crank fast enough?Alex B wrote:PS How would all except 1st plugs help estimate crip?
