Idle control using Stepper Motor (M400)
Guys,
I seriously have some issue with idle control using the stepper motor running m400 unit. I need to first understand how Motec control the stepper motor. With proportional gain set at 0.05, when I toggle the "polarity" between 0 and 1, I can see the stepper motor valve opening and closing. This is how I check to see if my wiring setup is correct or not. Now that I know the ECU has no problem controlling the valve, I started to play with the idle control setting to monitor how the valve react and this is where I got lost.
First and foremost, I have the idle control wiring up BUT not plumbing into the system. The engine is still running without idle control and the engine is idling fine. The reason I want to add the idle control is because in order to idle properly in cold start, I have to set the idle to around 1000rpm but that also mean during hot idle the engine is still idling at 1000. I know that once the engine is hot, I can have it idle properly at 800rpm and that's the goal with the idle control module I'm adding.
Now, back to the idle control setting, i understand what PID is. My question is, in the motec software, what does initial position mean? what does normal position means? what about Min and Max output?
Can someone explain how motec control stepper type idle control. Should the initial position be fully closed or fully wide open? and normal position mean? What is consider normal?
Help please.
Help please.
