ECU to PC communication problem with UTC
Posted: Tue Nov 25, 2008 6:27 am
We are using Motec M880 and ADL dash logger on our Yamaha R6 powered Formula SAE race car. We are very familiar with ADL but have just made a initial startup with M880. Everything went very well and without even a single problem until now. We had already made quite a lot tuning on a superflow engine dyno when suddenly communication between ECU and PC got unstable. Engine idles and revs nice but immediately when you get on full load-> ECU Manager freezes-> starts to read ECU data-> again freezes-> starts to read ECU data-> etc. When you decrease the load/TPS everything works fine again. Engine works fine all the time. Strange thing about everything is that the setup might work fine for couple of days but suddenly can't get stable communication at all. Also strange is that communication between ECU & ADL is never interfered.
Our current setup is M880 with M&W CDI, ADL dash and UTC adapter. ECU is fitted to superflow frame and connected to ADL&UTC outside the dyno room with 2m long twisted pair CAN. CAN has a 100ohm resistor at both ends (UTC also has a internal 100ohm resistor).
I have tried almost everything but problem stays. All the wirings has been done properly, all the communication wires have been checked & done by following the motec manual, CDI & other interference has been excluded, ground points separated & checked, several resistor setting tested on the CAN, removed the ADL, changed the PC, re-installed the softwares & drivers, changed the UTC & USB wire.
First I thought it would be some external interference but while scoping the CAN traffic I noticed that UTC makes quite a lot noise to the signal?? I'll attach some lousy pictures but hope they make the point:
I'll be re-posting if something unmentioned comes to my mind.
Thanks,
Lauri Eho
Thanks,
Lauri Eho
