GSXR cam sensors
GSXR cam sensors
Postby Sean on Wed Apr 02, 2014 6:58 pm
Hi all, I have read of problems with the earlier standard 2 wire Suzuki cam position sensors with M400. We have one on a GSX based drag bike engine and it seems to be giving us trouble, with an offset signal.
Was wondering what people are using, aftermarket or the later 07 up 3 wire Suzuki sensor?
Sean
Re: GSXR cam sensors
Postby thorstengsxr on Fri Apr 04, 2014 8:25 pm
Hi Sean
I use this one http://www.dataspares.com/sensors-2/cam-sensor-bracket-suzuki-hayabusa-gsxr and it works perfect for many yaers. But this is only one part of the problem. the other part ist the position of the cam pin. The signal come to same time like the missing of the crank. So I decide to change the cam pos about 180 on the other side
regards Thorsrten
PS look at this side it is in german but it shows some intersting things for gsxr and goldboxhttp://www.racebikesonline.de
thorstengsxr
Postby Sean on Sun Apr 13, 2014 7:23 am
Thanks Thorsten, had not seen that bracket before, seems like a good idea, will give it a try. Pin position is not a problem in this engine, we are sensing direct off a cam lobe.
thorstengsxr wrote:PS look at this side it is in german but it shows some intersting things for gsxr and goldboxhttp://www.racebikesonline.de
This is your site Thorsten? Some interesting things there. What model GSXR is that? I have had K2, 5 and 9 myself :D
Sean
Postby AlanB on Mon Apr 14, 2014 7:29 pm
What Thorsten says about the cam pin position used to be correct, where the M800 would not sync up when the sync edge was in the missing teeth on the ref input.
This was applicable to mode 7, but there is now a dedicated ref/sync mode which does not require the sync edge to be moved; mode 68.
Alan Bell
MoTeC Europe Ltd
AlanB
Postby thorstengsxr on Mon Apr 14, 2014 8:38 pm
Hi Sean
It's a good old K5, at the Moment i build a new bodywork for the bike and yes this is my old blog
@Alan
thanks for the info i will test it as some as posible.
regards Thorsten
thorstengsxr
Postby spyro512 on Fri May 30, 2014 4:46 am
I'm using mode 7 on a k5 GSXR600 engine on a M400 and a M84.
No engine modifications have been done and it works perfectly :shock:
spyro512
Postby thorstengsxr on Tue Jul 01, 2014 6:17 pm
Hi spyro
The gsxr 600k5 is a good old 8Bit ecu engine this is completely different the the 16bit konfiguration of the newer versions. So it can be posibel that in your config everything works fine.
PS I change to Mod 68 and it works fine for me thx Alan
regards Thorsten
thorstengsxr
Users browsing this forum: Bing [Bot] and 9 guests
