E888 secondary injector outputs
Mon Mar 31, 2014 8:15 pm
by dazzadude
Hey guys,
How many injectors can I run off an e888?
I want to add 6 secondary injectors to my M800 / e888 setup.
I have used up all most m800 outputs, I still have 2 injector outputs available in the m800 can I run 4 out of the m800?
Thanks.
Re: E888 secondary injector outputs
Thu Apr 03, 2014 7:40 am
by Scott@FP
Expander outputs can be assigned to almost anything (within their capabilities) except ignition or injection. Its a CAN msg at 200Hz and any table info is held in the Mx00, in fact ALL cal info is held in the mx00, think of an expander as a dumb box. If you want 8 table operated outputs you lose all 8 ind cyl injector trims. Even numbered E888 outputs are low freq (100Hz) low res 0-100% in 20 steps), odd numbered are high freq (5K Hz) high res (0-100% in 255 steps).
For an m800 and a 6 cyl with primary and secondary sequential injection when you enable the secondaries they use inj 7,8 and ign 3,4,5 and 6. So if you want waste spark or sequential ignition you need to run the ign from an ignition expander from ign 1 which leaves ign 2 open.
