Can someone explain how to wire a digital input switch. To what pin should it go and should i ground it to 12V. I am trying to wire a switch to turn anti-lag on and off
Raheel Farouk wrote:...And should i ground it to 12V.
Scott@FP wrote:…Just ground it to go below the switch threshold voltage, its like 3.5v going up and 1.0v going down.
Raheel Farouk wrote:Scott@FP wrote:…Just ground it to go below the switch threshold voltage, its like 3.5v going up and 1.0v going down.
So if I ground it to the 0V aux that would be fine right?
Scott@FP wrote:Raheel Farouk wrote:Scott@FP wrote:…Just ground it to go below the switch threshold voltage, its like 3.5v going up and 1.0v going down.
Yes both the digital inputs 1-4 and the AT 1-6 already have a 5v pullup so just ground to 0v engine or aux with the switch and set up the parameters.
