table options/channels
Sat Jan 04, 2014 8:17 am
by sphilips
In for example the fuel table you can select 'properties'. Then you see a list of channel you can add of delete. What is the purpose of this? I don't find it in the manual.
Re: table options/channels
Sat Jan 04, 2014 9:14 am
by Sean
These channels are the ones that appear as a numeric list in the small box under the main tables, so you see trims and compensations etc when the engine is running. You can add or remove channels as required, and change how they are displayed.
Sun Jan 05, 2014 5:50 pm
by sphilips
as diagnostic purpose?
Tue Jan 07, 2014 9:53 pm
by Sean
When the engine is running I use the option channels so I can check that the fuel and ignition comps are not doing anything strange, so diagnostic, yes.
