Toyota 3sge & M400 without rpm reading
Hi, please I need some help with an issue that I have with a recently wired package.
The basic info is : Toyota 3SGE engine & M400 with original 3SGE distributor only for ref and sync signals because the
setup is coil per cylinder , MSD coils and MSD DIS 4 ignition module.
The problem is that the ECU doesn t see any rpm reading when cranking the engine on the sensor view screen,
and on the diagnostic errors screen the ref/sync not synced condition is always in red, all other sensors have good
signal because I dont have any other diagnostic error and all sensor measures are right.
Also there is not any ref/sync capture reading.
The starter motor is in good condition , battery voltage is good, also I try with a jumper battery and another distributor but nothing changes the not synced condition and zero rpm.
The wiring to the distributor is very simple only three wires : ref, sync and 0v (engine).
I wired the distributor and do all the ref/sync sensor setup on the ECU manager as stated on the Toyota 24 tooth
magnetic Motec drawing (T11).
Also there is some data that I not sure how to enter on the ref/sync sensor set up:
Ref sensor filter: 1.0
Sync sensor filter : 1.0
Ref/sync rpm site: 7000 rpm
ref magnetic levels: 2.0 volts
sync magneic levels: 2.0 volts
But It appear that all this data is pre difined on the ECU manager .
But the main problem is the zero rpm reading, I am not sure if the lack of this exact data is the problem for the
zero rpm reading and the not synced condition.
I am going to apreciate a lot some guidance with this issue.
