M600 EGT variance on 20B engine
I have an M600 conneted to an N/A 20B 3rotor engine.
It has 6 coils, 3 leading and 3 trailing, and 3 injectors (one per rotor). I am using ignition mode 140, I have the engine set as -3, and am using the instructions from T12.pdf regarding ignition setup - ref/sync mode 2, 12 teeth, CRiP 20, and the appropriate mag level tables. I've checked the timing using the Test Advance screen (pulley has a notch at -5*) and it seems to be dead on.
Engine starts and seems to idle fine, but I have quite varied EGT numbers between the 3 rotors; for example #1 is 700*F, #2 is 1200*F and #3 is 400*F at around 2000rpm. We have checked the injectors and coils, checked for leaks, ITB misalignment, basically all mechanical issues appear to be OK.
I do have several ref/sync errors in the Diagnostics view - ref noise ar, ref noise tr, ref runt and ref low level (as well as on the sync side). I have been experimenting with the filter levels and mag levels after looking at the ref/sync capture but can't seem to get rid of these.
Is it possible that these errors can cause issues leading to the EGT problems above?
Any advice appreciated!
