Reading RS-232 data from M800 using an Arduino Uno
Hi everyone!!
I have been trying to read the data coming out of the RX pin of the M800 ECU using the pin 10 of the Arduino Uno ( which I have previously set as a virtual RX pin). The Arduino module is connected to my laptop. The ECU is connected to another laptop via a CAN to USB converter and is sending dummy sensor data to the Arduino. I have looked at the data sending protocol of the ECU, but have not been successful yet to extract anything but nonsense. Here's my code:Please before going through the code have a look at the data sending protocol of the ECU which I have attached.
Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
* RX is digital pin 10 (connect to TX of other device)
* TX is digital pin 11 (connect to RX of other device)
Note:
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created back in the mists of time
modified 25 May 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
#define head0 0x82
#define head1 0x81
#define head2 0x80
#define marker1 0xFC
#define marker2 0xFB
#define marker3 0xFA
int rpm[2];
int RPM = 0;
char ET[2];
float EngTemp;
void setup()
// Open serial communications and wait for port to open:
Serial.begin(19200);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("Goodnight moon!"); // test
// set the data rate for the SoftwareSerial port
mySerial.begin(19200);
//mySerial.println("Hello, world?");
void loop() // run over and over
if (mySerial.read() == head0){
Serial.println("RPM");
if (mySerial.read() == marker2){
if (mySerial.read() == marker3){
//skip next byte
// mySerial.read();
//RPM read next 2 bytes
//rpm[0] = mySerial.read();
//rpm[1] = mySerial.read();
//RPM = rpm[0] << 8 && rpm[1];
if (mySerial.available())
Serial.println(mySerial.read());
The circuit:
Note:
by Tom Igoe
#define head0 0x82
#define head1 0x81
#define head2 0x80
int rpm[2];
int RPM = 0;
char ET[2];
float EngTemp;
void setup()
while (!Serial) {
//skip next byte
// mySerial.read();
