Reading RS-232 data from M800 using an Arduino Uno
Postby jimbojohn on Thu Sep 12, 2013 6:25 pm
Hi everyone!!
I have been trying to read the data coming out of the RX pin of the M800 ECU using the pin 10 of the Arduino Uno ( which I have previously set as a virtual RX pin). The Arduino module is connected to my laptop. The ECU is connected to another laptop via a CAN to USB converter and is sending dummy sensor data to the Arduino. I have looked at the data sending protocol of the ECU, but have not been successful yet to extract anything but nonsense. Here's my code:Please before going through the code have a look at the data sending protocol of the ECU which I have attached.
Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
* RX is digital pin 10 (connect to TX of other device)
* TX is digital pin 11 (connect to RX of other device)
Note:
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created back in the mists of time
modified 25 May 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
#define head0 0x82
#define head1 0x81
#define head2 0x80
#define marker1 0xFC
#define marker2 0xFB
#define marker3 0xFA
int rpm[2];
int RPM = 0;
char ET[2];
float EngTemp;
void setup()
// Open serial communications and wait for port to open:
Serial.begin(19200);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("Goodnight moon!"); // test
// set the data rate for the SoftwareSerial port
mySerial.begin(19200);
//mySerial.println("Hello, world?");
void loop() // run over and over
if (mySerial.read() == head0){
Serial.println("RPM");
if (mySerial.read() == marker2){
if (mySerial.read() == marker3){
//skip next byte
// mySerial.read();
//RPM read next 2 bytes
//rpm[0] = mySerial.read();
//rpm[1] = mySerial.read();
//RPM = rpm[0] << 8 && rpm[1];
if (mySerial.available())
Serial.println(mySerial.read());
PSAU0015 MoTeC M800 Set 3 Data Protocol.zip
(941.39 KiB) Downloaded 1471 times
jimbojohn
Re: Reading RS-232 data from M800 using an Arduino Uno
Postby David Ferguson on Fri Sep 13, 2013 5:13 am
I would expect an M800 to TRANSMIT it's data on it's TX pin, and RECEIVE data on the RX pin.
Postby jimbojohn on Mon Sep 16, 2013 3:25 am
Good call. Sorry that was my mistake, I apologize for my clumsiness. I have actually connected the TX of the ECU to RX of the Arduino. You see, I am quite sure that I receive stuff from ECU, but cant receive them in the right way. So, all I see is nonsense, but I am sure it is something which is being received from ECU. I am almost certain of it. The problem is that I dont know how to check what data is being sent and when they are sent.
jimbojohn
Postby David Ferguson on Mon Sep 16, 2013 4:59 am
Why don't you start by printing to your console all the bytes you receive (in hex). Use something like:
uchar dataByte, buf[16];
dataByte = mySerial.read();
sprintf(buf,"0x%x ", dataByte); // for debugging only
Serial.println(buf); // do this for debugging only
Then you can look at what comes in and decide what to do with it.
switch (dataByte == head0){
head0:
Serial.printIn(" : head0 found\n"); // for debugging only
break;
head1:
Serial.printIn(" : head1 found\n"); // for debugging only
break;
// add more decoding here...
default:
Serial.printIn("\n"); // it's just a value so end the line (for debugging only)...
I hope that helps....
Postby jimbojohn on Tue Sep 17, 2013 10:54 pm
Hi there!! me again.
I actually made some slight changes to your code(cause I had to due to some errors) tested it. Your code actually makes a lot of sense to me and when I looked at it I thought "this should work". So I really appreciate your effort.
For some reason the result I got out of "serial.println(buf)" was independent from "dataByte" and made no sense. However it occurred to me that it changes when I change the size of "buf" (which is 16). So when it was "buf[16}" it spit out "0x8d4" on Arduino's serial monitor and when I changed "16" to "15" it changed to some other value. I believe it has something to to with the way sprintf() works, but I couldnt figure what it is. My aim was to only try the first half of the code so I can see the results that are thrown out of the ECU.
I also tried using "dataByte" as an "unsigned char" without 16 elements, but each time "buf" throw out "0xff". Just thought to mention that.
Here's the modified code that I used:
#include "stdlib.h"
//#include "stdafx.h" // Apparently the source of this couldnt be found
#include "Arduino.h"
char head0 = 0xFC;
char head1 = 0xFB;
char head2 = 0xFA;
char rpm[2];
int RPM = 0;
char ET[2];
float EngTemp;
void setup(){
unsigned char dataByte[16];
char buf[16]; //I had to make it char cause sprint() would give me error in unsigned char* to char* conversion, but apparently this does not influence the sign of dataByte
for (int i =0; i<17;i++){
dataByte[i]=mySerial.read();
//dataByte = Serial.read();
Serial.print(buf); // This seems to be absolutely independent of whats in dataByte (there maybe something wrong with sprintf()), but I get 0x8d4 when buf has 16 members and this value changes as I change 16
/* for( int j = 0; j<17; j++){
switch (dataByte[j] == head0){
head0:
Serial.println(" : head0 found\n"); // for debugging only
break;
head1:
Serial.println(" : head1 found\n"); // for debugging only
break;
default:
Serial.println("\n"); // it's just a value so end the line (for debugging only)...
void loop(){
/*if (mySerial.available()){
Serial.println(mySerial.read());}*/
jimbojohn
Postby David Ferguson on Wed Sep 18, 2013 3:01 am
Sorry but I'm not going to be able to teach you how to program in C in this forum.
Because you declared dataByte to be a an array, when you pass it to sprintf, you are passing a pointer to the array. The reason you get the same value is because the array is at a constant address.
Try this:
for (int i=0; i<16;i++){ // note, array is 16 elements long, so the index goes from 0 to 15 not 0 to 16!
// to prove the following code you might want to initialize the dataByte array to known values like this:
// for (int i=0; i<16;i++){
// dataByte[i]=i;
for (int i=0; i< (sizeof(dataByte) / sizeof (dataByte[0]); i++){ // notice how I made the loop count automatically track the size of the dataByte array?
sprintf(buf,"0x%x ", dataByte[i]); // for debugging only
Serial.print(buf);
Please practice on your own, or use internet resources like stackoverflow.com to get help in programming topics.
Postby jimbojohn on Thu Sep 19, 2013 2:17 pm
Thank you very much for your help. Sorry if I violated the rules a little bit for asking a lot of programing related questions. This forum has helped me a lot with my progress than other forums have.
Cheers :D
jimbojohn
