M800 tach output to drive a Stack ST700 tachometer
Trying to make the tach output of an M800 drive the needle on a Stack ST700 dash display.
I have Aux4 set to tach output, have this wired into Engine Speed on ST700. Have dash configured per engine type and number of cylinders but no love.
Stack manual suggests to connect a 1Kohm pull up resistor from B+ to this tach signal but to check with ECU maker that this wont blow up said ECU.
So that is the question(s),
A) does one need to add a pull up resistor to get the ST700 to work?
B) will doing so hurt the M800?
thanks
andrew
thanks
andrew
