Suggest a small magnetic ref sensor.
Hi, I am after suggestions for a small magnetic ref sensor, about 12mm diameter, maybe 40 ish mm long, preferably with a threaded body. I can't really make head nor tail of RS or Farnell's catalogs
It's for a drag bike application, so will see up to 14K rpm at times, and it's a harsh environment with heat and vibration. Using a simple 8 tooth trigger wheel, and M400.
Thanks for your suggestions.
