M800 on E30 M3 (1989)
Hello to all, I am currently working on completing a harness for the E30 M3 that will be used with the M800. I would like to ask for help about a few things.
1) The engine has a cylinder identification sensor (DME pins 25 and 26).
2) An engine speed sensor that reads the flywheel teeth (DME pins 8 and 27).
3) A TDC sensor according to the ETM (but is not connected to the DME).
Q: May I know which among these should be used for the REF and SYNC inputs? I have read that some are using some other type of trigger wheel and sensors. Can someone provide me info or a link to some info about this?
4) There is a BARO pressure sensor (DME pin 30).
Q: Can I use the Manifold Pressure input (A15) on the M800 for this? Is is advisable to make use of this sensor instead of a MAP sensor?
5) There is an integral sensor that combines Air Temp and Vane Airflow Meter
Q: If I connect these pins to the M800 directly will it work? In the ETM the sensor (supply) reference voltage (5V) flows through the Vane Airflow Meter resistance before it goes to the Air Temp sensor so I am inclined to think that the Air Temp sensor does not receive the full 5V reference.
6) Do I need to install another TPS on this setup? In the ETM, it looks like it is only a switch for closed throttle and WOT.
I have experience with wiring up and software setup of the I/Os of aftermarket ECUs like the AEM, ViPEC, and Motec (for the Mitsubishi EVO) but they were more or less straightforward as compared to this one for the E30 M3. I need help with this one so if anyone is willing to provide suggestions or a pinout chart of their setup, please do.
