Nitrous setup
Hi again,
I would like to know if anyone here can explain me the steps to install a nitrous solenoid. The injectors will supply fuel. I know that I have to connect it to one aux, but then if someone can explain me how to make it progressive, let say as from 4000 rpm to 6500rpm. My main rpm limit is 7000rpm. I'll be using a 50shot NOS kit and using 1050CC injectors.
Also if you can explain me for the throttle that it will be activated and how to put conditions to it.
Thanks a lot for your help.
cheers
cheers
