Ignition Wiring and Software Setup
Hi
I'm a student of ETH Zürich and I'm working on the project SUNCAR, we are using a single cylinder 4 stroke engine with an electric generator to charge the battery of our series hybrid car.
We are using the M400 ECU, and our ignition system include a ignition modul of bosch 0 227 100 211 and a ignition coil of delphi 28198992.
Last week we would like to test the CAN connection between the vehicle control unit and the engine control unite to control the throttle position, when the ignition coil began to "burn".
The wiring has been controlled and it is ok. In the software we changed nothing. What we found out is that the ignition coil always receives power from the ignition modul, the ground connection was always closed. The cause is that the A3 port of M400 not work.
We have 3 more port on the ECU that we can use, but I don't want to burn also them
someone has already had this problem? Do you know what could have caused it? If I want to use the port A4, A5 or A6 I have to change something in the software?
Thanks in advance
Martino
Thanks in advance
Martino
