AV inputs be assigned for other things?
I have the following doubts, (using a subaru my99pnp ecu on ej20 with modern quad cam control, wiring modified to suit quad cam control ofcourse)
I want to reassign two(two cam ctrl) or maybe four (quad cam ctrl) digital inputs that are currently being used for gear cut, dual rpm, log enable and speed measure to any available AV inputs
OR reassign ATfunctions to AVinputs to free ATinputs which sounds better since speed measure will probably wont be possible in the AVs
that way I can assign the free digital OR AT inputs for quad cam control on an ej20.
First off, how do I know if quad cam control is enabled within my options? Maybe I have to get a password to enable.
Current AT inputs are being used in the following way:
AT1=IAT
AT2=ECT
AT3=(cant use for some reason it is 12v constant in this pnp model ecu)
AT4=ORB select
AT5=Scrambleboost(timer1)
AT6=Boost trim.
AV inputs are currently being used in the following way:
AV1=tps(cant use)
AV2=map(cant use)
AV3=MAF(could use)
AV4=BAP (barometric pressure, not sure if this sensor is internal, if not it could be used?)
AV5=(could be used)
AV6=(could be used)
I have 4 Auxoutputs available to drive the cam solenoids...
Is this possible? How has anyone out there wired/assigned quad cam control inputs/outputs?
AT1=IAT
AT2=ECT
AT4=ORB select
AT6=Boost trim.
AV1=tps(cant use)
AV2=map(cant use)
AV3=MAF(could use)
AV5=(could be used)
AV6=(could be used)
