TPS with MAP+BAP compensation
We are running a na 600cc Formula SAE engine with M880. We use TPS for efficiency calculation with MAP compensation. The question is should we also run a barometric pressure compensation? Another issue is the restrictor that causes the MAP reading to fall at high rpms when the restrictor chokes. Should we just turn off the MAP compensation at high rpms?
