Which sync/ref model suitable for 1GR FE engine?
Tue Apr 30, 2013 7:23 pm
by MichaelLee
I have attached Sync signal.
[img]1GR.JPG[/img]
Re: Which sync/ref model suitable for 1GR FE engine?
Wed May 01, 2013 3:59 am
by Martin
Mode 33 on the M800. Ive got a lot of 1GR FE configs and could help you if you want.
Wed May 01, 2013 1:57 pm
by MichaelLee
Thanks, Martin. I will try 33 mode on the M800. The best there is a start file if you can supply.
Wed May 01, 2013 5:41 pm
by Martin
pm me your email address
Thu May 02, 2013 3:51 am
by stevieturbo
delete
Fri May 31, 2013 2:40 pm
by MichaelLee
Martin wrote:pm me your email address
Hi Martin
I have setup sync/ref same with your map, but the ecu still can't synchronized(show "error sync signal").
Fri May 31, 2013 4:04 pm
by Martin
post a ref sync capture and your config
Sat Jun 01, 2013 8:11 pm
by MichaelLee
Martin wrote:post a ref sync capture and your config
I have attached a sync signal capture and config
Mon Jun 03, 2013 3:01 pm
by Martin
Your ref sensor edge is incorrect. Should be falling.
