I received a friend's map made by a Pro Mapper and found on the logs that the PWM idle valve had a duty cycle (40%) even out of idle, that is to say on boost.
So I looked at idle initial position table and there do is a 40% value there.
Question is... won't boost pressure go out of the idle valve in this way?
What Idle initial position table is for then? NA cars? Other kind of valves?
