External lambda on M400
I have just fitted a second lambda on my M400, it is an Innovate system with a 4.9 LSU. I do not have the La2 upgrade so have used AV5 as the signal input. Can anyone tell me if this will work OK and what parameters to use for the input setup, would #40 lambda bosch wide band meter work?
I am assuming my M400 needs an upgrade to use La2?
Thanks for your help.
